Shivam
Jun 6, 2022 4:41 PM UTC
Is there any official example code for device firmware update over USART for STM32 MCU?
I've referred their AN3155 and AN2606 but I wanted to know whether I can find an official implementation of the flows mentioned in their application notes. Also I wanted to know the duration for which the RST pin of the controller has to be pulled LOW so that it considers it as a valid RESET. This is needed so as to put the MCU into DFU mode (Bootloader) by resetting the MCU while the BOOT 0 pin is being held HIGH. I'm using STM32F0 and STM32G0.
Tesla DeLoreanBest answer
Jun 6, 2022 5:03 PM UTC
No
You're kind of expected to be able to code something that implements the protocol described.
There are several open source examples that implement it.
Doesn't the Data Sheet say >=500 ns
The other IAP examples use a standard protocol.
https://github.com/arduino-libraries/MKRWAN/blob/master/examples/MKRWANFWUpdate_standalone/MKRWANFWUpdate_standalone.ino
No
Shivam
ShivamAuthor
Jun 7, 2022 6:43 AM UTC
Thanks for your time. I found it helpful.
Shivam
ShivamAuthor
