SGK
Jan 10, 2023 7:07 AM UTC
is there any example to play audio from the internal memory to the touch gfx ? i am using stm32h7 eval board.
Osman SOYKURT
Jan 13, 2023 11:00 AM UTC
Hello SGK,
There's no Audio Demo available in TouchGFX Designer 4.21.0, however you can find an example from the packs downloaded by STM32CubeMX : The demo is compatible for TouchGFX 4.12.0 so it's really old, and some file might be missing (the audio examples for instance). But I guess you can use it as base to build your own application :)
It should be available from here :
C:\Users\YOUR_USER_NAME\STM32Cube\Repository\STM32Cube_FW_H7_V1.11.0\Projects\STM32H7B3I-DK\Demonstrations\AudioPlayer
/Osman
