HSing.2
Jul 10, 2020 6:38 PM UTC
Is it required to have HSE clock source for custom bootloader using CAN bus for STM32F446RE
In the application note AN2606, it is mentioned that ST's bootloader for STM32F446RE requires HSE clock if CAN bus is used to upload the hex file.
Now, if I am writing my own custom bootloader to upload the code via CAN, would I still need the HSE clock. Is possible to route HSI clock for the system clock and APB1
Thank you.
Snippet from AN2606
Jul 10, 2020 7:44 PM UTC
You can choose to clock it via any source you want, even ones which are out-of-spec. As long as you're willing to deal with things not work on an occasional unit, and support of that, you can use the HSI
