Senior
May 9, 2024 8:06 PM UTC
Is it possible to have faster tick rates on FreeRTOS?
I was about to configure the FreeRTOS for my project when I noticed the following:
TICK_RATE_HZ
TICK_RATE_HZ must be between 1 and 1 000.
Parameter Description:
Sets the tick interrupt frequency. The value is specified in Hz.
Warning:
The max value is 1000, as higher values generate compilation errors (division by zero)
Does it mean 1000Hz is the fastest FreeRTOS can work with, and anything else should follow a bare-metal approach?
I found this related topic, but it is not clear to me if that applies to STM32. Hence, I would appreciate the opinion of the experts here.
Andrew Neil
Andrew NeilBest answer
May 9, 2024 10:49 PM UTC
It means what it says - that is the fastest tick rate that is allowed*.
Note that this doesn't mean the fastest CPU clock rate which can be used...
It's not specific to any particular microcontroller - it's a FreeRTOS thing.
So you'd be better asking on the FreeRTOS forums.
EDIT:
*  Actually, from the post you cited, and others such as this:
https://forums.freertos.org/t/freertos-high-tick-rate-for-machine-control/6913
it seems that tick rates >1kHz are possible - but strongly advised against.
Both of those posts give some reasons why it could be a Bad Thing.
You'd probably be best explaining your actual goal on the FreeRTOS forums, and asking them for their advice on how best to achieve that within FreeRTOS.
AScha.3
May 9, 2024 8:16 PM UTC
I am not an expert for rtos...but what the AI says :
According to the search results, a moderate task switch rate is around 300 per second per processor. However, this rate can vary depending on the system’s usage and configuration.
Right.
This is not specific for a cpu - its the rtos system, you choose. Look at Azure, standard is 10ms tick.
But you can set it up to 1ms, same as FreeRTOS .
Andrew Neil
EDIT:
