Jtron.11
Senior
Jun 14, 2021 7:34 PM UTC
Is it possible to design a system using STM32F722 to have both USB MSC and SDMMC to read/write date to SD card both by MCU and by external PC interchangeable information on the same file in SD card?
I am looking for some guidance how to implement a system that utilize both SDMMC and USB MSC so I can read/write data inside SD card from MCU and external PC.
Thank you for your helps
Jun 14, 2021 8:16 PM UTC
You'd have to manage cache-coherency for the PC/Windows side of things otherwise all manner of corruption can occur.
The MSC/SCSI layer can generate sense codes indicating the media is write only, and has been changed, etc.
