Caan
Apr 22, 2025 1:54 PM UTC
Interfacing Multiple ADC Channels for Data logging
Moved from TouchGFX forum
Greetings Community,
                                   I need advice on data logging multiple ADCs and/or ADC Channels to interface 40+ Train Gauge Values on an MCU that can show data on LCD or transmit Data over USB or serial to a PC.
Apr 22, 2025 2:06 PM UTC
That's a lot of different things. Build it up in pieces. Take an ADC value. Send data to PC. Show data on LCD. Do these separately and then combine.
Caan
CaanAuthor
Apr 22, 2025 2:15 PM UTC
Thanks for the startup process, I want to know the best possible method of getting Multiple ADC Differential channels interfaced, either using a Multiplexer with a single channel 24 24-bit differential ADC and scanning the individual channel, or using separate ADCs with 2-4 Channel combination.
Andrew Neil
Apr 22, 2025 2:22 PM UTC
You need to define what you mean by "best"; eg,
  • lowest cost
  • least components
  • highest precision
  • highest throughput
  • lowest error
Or, better, give some actual specifications (or ranges) ...
Andrew Neil
Apr 22, 2025 2:09 PM UTC
What "advice", exactly, do you need?
You've posted in the TouchGFX section - so is your question focussed on that area of the problem?
How to write your question to maximize your chances to find a solution
Did you mean Strain Gauge ?
