AKhar.5
Apr 18, 2023 3:07 PM UTC
IEEE-488 (General purpose interface bus / GPIB) implementation
I would like to implement IEEE-488. on stm32.
In order to connect send commands and download data from old digital equipment.
Does someone familiar with GPIB library code implementation?
Apr 18, 2023 4:01 PM UTC
I think there are commercial products that do this.
Perhaps pick a protocol you're familiar with, or you can read/interpret the specification for, as your initial task.
Check GitHub and the wider internet for projects of this nature, on the STM32, and similar MCU, that you might be able to port, or at least get some understanding or perspective from?
Peter BENSCH
Apr 18, 2023 8:41 PM UTC
...i.e. this implementation for GPIB running on STM32.
Good luck
/Peter
DiBosco
Senior
Apr 8, 2024 4:04 PM UTC
Hey Peter,
Am assuming you are the same Peter Bensch I used to work with back in the naughties. If so, hello! :)
I've been looking at this software as I need to implement a GPIB device and documentation is sketchy to say the least. This is some weird code, it has an include file for a PIC and some of the functions it calls don't exist. Do you  know anything about it, or is it just something you found on a Google search?
Cheers!
Rob (from Manchester)
