GirishKumar
Nov 23, 2022 1:50 PM UTC
I would like to do a secure boot on B-L475E-IOT01A: development board. CAn any one share me a tutorial or steps on doing a secure boot on B-L475E-IOT01A: I am using Azure RTOS.
Nov 23, 2022 7:31 PM UTC
Hello @GirishKumar​ ;
I'd highly recommend you the X-CUBE-SBSFU' (Secure Boot and Secure Firmware Update solution).
 It allows the update of the STM32 microcontroller built-in program in a secure way.
The software comes with an SBSFU example implementation running on B-L475E-IOT01A.
STM32CubeExpansion_SBSFU_V2.6.1\Drivers\BSP\B-L475E-IOT01\
A documentation is available:
  •  UM2262 getting started with the X-CUBE-SBSFU
  • AN5056 Integration guide for the X-CUBE-SBSFU
  • AN5447
Imen
GirishKumar
Nov 24, 2022 7:19 AM UTC
Thank you very much Imen for your response.
I will read through it and get back to you
