IIvan.6
Jun 30, 2021 5:49 PM UTC
I want to try SPL2LL-Converter under Windows - but how can I start it??? Luckily, I have Oracle JRK but it doesn't help much, because GUI is disabled (grayed)
houssemeddine
Jul 1, 2021 8:35 AM UTC
Hello @Community memberov​ ,
you need to install ActivePerl in order to run the SPL2LL-Converter.
I recommend you to use ActivePerl 5.24.1 or later.
Can you please give me your feedback after the installation?
Amel NASRI
Jul 1, 2021 9:44 AM UTC
Hi @Community memberov​ ,
Besides to @houssemeddine​ 's proposal, I suggest you to use the CLI version of SPL2LL-Converter.
Reference documentation that can help you:
-Amel
IIvan.6
IIvan.6Author
Jul 2, 2021 8:30 AM UTC
XML::Parser::Expat object version 2.46 does not match bootstrap parameter 2.44 at C:/Strawberry/perl/lib/DynaLoader.pm line 210.
Compilation failed in require at Modules/XML/Parser.pm line 18.
BEGIN failed--compilation aborted at Modules/XML/Parser.pm line 22.
Compilation failed in require at Modules/XML/Twig.pm line 129.
BEGIN failed--compilation aborted at Modules/XML/Twig.pm line 129.
Compilation failed in require at spl2ll_converter.pl line 50.
BEGIN failed--compilation aborted at spl2ll_converter.pl line 50.
vneff
Feb 10, 2022 9:40 PM UTC
I am also seeing the same compile errors!
