LSmil.1
Jan 6, 2022 10:00 AM UTC
I'm using stm32h753, no LWIP project. Eth Tx is not working.
Hi All,
I'm using stm32h753, no LWIP project. Eth Tx is not working. HAL_ETH_Transmit - keep failing with DMA transmission - I have seen few posts about that issue - I tried all the solutions I saw - none worked...
Any help is most appreciated!
Muhammed Güler
Senior III
Jan 7, 2022 9:20 AM UTC
I appreciate you trying to work with ethernet without using lwip. I don't know what you want to do, but I think LWIP RTOS and socket api is the most comfortable way to work with ethernet. I'm putting the cubemx project I created with nucleo-h753zi below. I hope it helps.
