Shilpashree Madhu
Dec 15, 2021 10:34 AM UTC
I have done custom bootloader, it should be jumped to application but it isn't going to jump to the application address, hard fault error is showing up?
Dec 15, 2021 12:10 PM UTC
Debug normally as you would for a Hard Fault, look at the instructions and registers at the point it faults.
D​etermine if data being read is correct, and addresses are correct. If doing a control transfer that there is viable Thumb code there.
S​tep code transitions in a debugger.
H​ave your HardFault_Handler output actionable data.
