arilink
Jul 27, 2021 2:41 AM UTC
I have a lot of questions about USBX
  1. How does the FIFO created in MX_USB_Device_Init() match the endpoint?
  2. In the USBX document of Azure, the descriptor is directly made into an array, while the sample program uses a lot of functions to implement it. What are the benefits of this? Not easy to analyze
  3. ux_app_parameters_change() corresponds to CDC Control. How can I operate CDC Control to change the baud rate and other operations?
  4. ux_device_class_cdc_acm_read() reads data. How to make sure it reads the correct endpoint data?
  5. Initialize USBX Memory size is 32K Is this the smallest memory value? Can it be reduced
Walid ZRELLI
Jul 29, 2021 11:11 AM UTC
Hello @arilink​ ,
Your questions have been raised internally and I will keep you posted.
Thanks for your contribution.
BeST Regards,
Walid
