Rajesh Raturi
Dec 15, 2021 7:04 AM UTC
I am trying to implement multiple virtual COM ports using one USB. I changed the no. of interfaces and device descriptors from 1 to 3 but is it still showing a single VCP. Would you tell me where I am lagging?
ESzes.1
Dec 15, 2021 7:36 AM UTC
As I understood the ST libraries doesn't support composite devices. I used a really good open source solution for it: https://github.com/IntergatedCircuits/USBDevice
This supports composite devices, you can find example projects there also.
Rajesh Raturi
Dec 15, 2021 8:42 AM UTC
I am doing this with threadX ( USBX ) help me to add a Virtual COM port
gbm
Dec 15, 2021 1:31 PM UTC
You didn't supply any detailed info, so just my wild guess: you re probably missing IAD, or Interface Association Descriptor - a component of the Configuration Descriptor. Find some info on the net regarding composite VCOM and its Config Desc. It won't work without IAD.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
Dec 15, 2021 2:15 PM UTC
