peterwei2010
How to run the STM32F107_ETH_LwIP_V1.0.0 example? STM32F10C-EVAL BOARD
  • June 22, 2010
  • 3 replies
  • 1527 views
Posted on June 22, 2010 at 12:07
#stm32f10c-lwip
jeffj2
Posted on May 17, 2011 at 13:55
Hi Peter, if just for effect you can try
NicheLite TCP/IP stack for the STM32F107xx microcontroller, can download here called AN3000
http://www.st.com/mcu/familiesdocs-110.html
There is a readme.txt in directory, hope can help. If you can speak Chinese I can show you step by step:)
jeffj2
Hi Peter, there is a IP address, you can type
222.45.145.228
 in your browser, that can show you STM32F107_ETH_LwIP_V1.0.0 example, then run cmd and type: telnet 222.45.145.228, you can touch the hello world example, if a firewall running on your pc, be sure it allowed your action. If you want, please try what I said ASAP, I can not expose my device all day long:)
Read your post, I sure you can make your board test done soon, that's all what I can do, good luck!
peterwei2010
thanks for your reply,jia !
the question that i have is not that how to config the lwip, but just how to use that example from st.com,on my stm32f10c-eval kit. (these functions,eg. , web server, hello world etc)
i want to see what can i do for our project,from this example.  we are very interesting in ethernet.(lwip). but i am new to this.
when i run that program example and chosed the mode( eg. MII, RMII mode ,changed the IP) , but finally found that, didn't not implement those functions.
jia, thanks again , i need your help.   i can talk with you in Chinese,   infact , my Chinese is much better than my English
