Pavel A.
May 5, 2022 8:04 PM UTC
"Doesnt work" is not very informative. Does anything work at all?
Can you pass enumeration of the mouse (read descriptors) ? Can you get raw report data from the mouse?
Ejunior007
May 5, 2022 8:42 PM UTC
yes, anything works. i connect the mouse via usb port or via mcu pins and nothing respond (the led is always off). in these code i use a callback function for every data (x,y) and will be displayed in PC via uart.
i use the A725 sensor.
Pavel A.
May 5, 2022 9:19 PM UTC
The LED always off can mean that the device does not receive power from the USB host.
 Have you tried to connect a simple mouse instead of the sensor?
