Mar 27, 2025 10:49 AM UTC
How to implement HTTPS webserver without FreeRTOS
I built a simple HTTP webservice with an F4,
Following the code provided by this tutorial made by ControllersTech
STM32 ETHERNET #6. HTTP SERVER PART 1 || Simple Webpage - YouTube
It works well.
Now I want to secure it without adding FreeRTOS
Would be possible to implement MbedTLS without FreeRTOS?
Is there different ways to secure my webserver?
Not using FreeRTOS is a requirement for my project.
Thanks for your help
Best regard
mbarg.1
Senior III
Mar 27, 2025 12:53 PM UTC
Should you decide to move to ThreadX NetXDuo, we can help.
Apr 28, 2025 10:35 AM UTC
Hi, Have you implemented the HTTPS without RTOS.  I am also trying to add the secure for the web page. I am facing issues.
Are you implemented that code?
If you implemented that code means you need to send the document . what you changed.
LCE
Principal III
Apr 28, 2025 10:53 AM UTC
This can be used as a starting point:
http://131.159.60.228/docs/md___1_8getting_started.html
Apr 28, 2025 11:03 AM UTC
Thanks for your response.
can you provide the https implementation using nucleo-h755zi-q . Otherwise provide with dual core micro controller implementation.
