PStee
Nov 6, 2019 3:19 PM UTC
How to I update a running RTC time and date on stm32L4
I understand that the registers are write protected and you have a clock synchronization issue, but I can not find the cube HAL level calls to do this.
waclawek.jan
Nov 6, 2019 4:42 PM UTC
What's the point of using Cube, if it's harder than reading the manual and writing a couple of assignments into registers?
Try to look at the examples in Cube.
PStee
PSteeAuthor
Nov 6, 2019 5:03 PM UTC
I am using the HAL_RTC_SetTime(&hrtc, &stimestructureput, RTC_FORMAT_BIN); which says it is doing these steps but it is failing to get the RTC back in init mode so the value can be changed.
PStee
PSteeAuthor
Nov 6, 2019 5:33 PM UTC
The ever so intuitive answer was to change StoreOperation from SET to RESET now it works
