May 29, 2025 5:11 AM UTC
How to get size of each directory using FileX
Hi ,
I am using STM32H725 board, I want to get the size of each directories present in my MMC chip.
I am using FileX for file and directory operations on an MMC chip. The chip is accessed via USB MSC
Thank you.
May 29, 2025 7:37 AM UTC
Hello @Riya
FileX does not provide a built-in function specifically for calculating the size of a directory. To achieve this, you need to manually iterate through the directory entries, sum the sizes of all files, and handle any subdirectories recursively. This involves using FileX APIs to navigate the file system and perform the necessary calculations.
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
RiyaAuthor
May 29, 2025 9:24 AM UTC
Could you please any examples ?
