SZhan.5
Nov 22, 2018 8:52 PM UTC
How to get funciont "hal_i2c_isdeviceready()" in LL library?
I am working on BlueNRG-2 and I need a funcion "hal_i2c_isdeviceready()" to confirm NFC eeprom IIC ready. In ST BlueNRG-2 demo, it used LL library of IIC.
Could you give me some demo like "hal_i2c_isdeviceready()" in LL library.
Thanks a lot.
Nikolay Brinken
Nov 22, 2018 9:31 PM UTC
  1. Before START check LL_I2C_IsActiveFlag_BUSY(I2Cx)
  2. Before TRANSMIT BYTE check LL_I2C_IsActiveFlag_TXE(I2Cx)
  3. Before RESTART check LL_I2C_IsActiveFlag_TC(I2Cx)
  4. Before RECEIVE BYTE check LL_I2C_IsActiveFlag_RXNE(I2Cx)
  5. Before STOP AFTER TRANSMITTED check I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED)
  6. Before STOP AFTER RECEIVED check I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)
Nikolay Brinken
Nov 22, 2018 9:41 PM UTC
points 5 and 6 are wrong
Jan 27, 2025 2:31 PM UTC
@SZhan.5
Did you find the LL solution for the above HAL function and test it?Please put it in the forum to use by others.
