How to generate only USB core middleware (without USB device class selected)?
I use custom USB device class implementation on top of ST's USB device stack (generated by CubeMX). I need only core implementation but i can not generate it without specifying some USB class from list in CubeMX!
This is pretty annoying because i have to delete unnecessary class code after any generation or rename directory with generated USB middleware library (and delete class) before next code generation to leave it untouched by Cube.
Could you add this feature (core middleware generation without class selected) or tell me how to do that without "hacks".
