How to flash a common bootloader on NUCLEO-G071RB
I am using a NUCLEO-G071RB development board. I accidentally erased the original bootloader while flashing a custom one. Is it possible to reflash or restore the built-in bootloader on the NUCLEO-G071RB development board? If so, where can I obtain the original bootloader file?
Thanks,
Aiswarya
Peter BENSCH
Peter BENSCHBest answer
Welcome @Aiswarya1, to the community!
It is impossible to erase the original bootloader – at least the one that was permanently stored by STMicroelectronics in the bootloader area. You can only erase a bootloader that you programmed yourself, which you may have programmed in the user flash.
Please describe what led you to believe that the original bootloader had been deleted?
/Peter
Peter BENSCH
/Peter
Aiswarya1Author
Thank you for your response.
I have uploaded the AM32 bootloader to the NUCLEO-G071RB development board. I believe the original bootloader was erased when I flashed the AM32 bootloader. Could you please let me know how to erase the custom bootloader that I programmed myself? If I select FULL CHIP ERASE, will it erase the entire bootloader as well?
Thanks & Regards,
Aiswarya
Peter BENSCH
Yes, when the chip is completely erased, your custom bootloader, which you previously programmed into the user flash yourself, will also be erased.
