Aug 31, 2026 01:09 UTC
How to display an image stored in external flash on the STM32H7S78-DK using the LTDC controller
Hello,I followed your reference and completed all the steps you mentioned before the screenshots.
However, I have two issues:
  1. Could you please provide a clear, high-resolution screenshot of Tools → Memory Management? The previous screenshot was not clear enough for me to read the settings.
  2. I am unable to flash the Appli project onto my STM32H7S78-DK.
This is what I did:
  • Initially, I cleaned both the Boot and Appli projects.
  • I built only the Boot project and flashed it onto the STM32H7S78-DK successfully.
  • Then, I built the Appli project.
  • When I try to flash the Appli project, I am unable to flash it onto the board.
Could you please explain step by step how I should flash both the Boot and Appli projects on the STM32H7S78-DK?
ELABI.1
ELABI.1Best answer
Aug 31, 2026 12:34 UTC
Hi ​@Berlin-raj123,
First of all, thank you very much for your feedback.
I have updated the picture to make it clearer and more visible.
I also downloaded the attached project and tested it by following the steps described in the article, the project works successfully.
I think the debug steps may not have been followed correctly. Please make sure the debug settings are properly configured and that the steps described in this article are followed carefully: “STM32CubeIDE: How to debug an STM32H7Rx/Sx project without flashing boot every time”.
Thank you.
ELABI.1
ELABI.1
ELABI.1Best answer
Hi ​@Berlin-raj123,
Thank you.
ELABI.1
Sep 1, 2026 12:06 UTC
​@ELABI.1  thanks for your reply, its working good , I would like to learn TouchGFX development using the STM32H7S78-DK board. Could you please guide me on the recommended way to get started? any example?
ELABI.1
Sep 1, 2026 14:02 UTC
​@Berlin-raj123
Thank you for updating post and glad to know that the issue is solved.
I recommend you to click on best answer on the reply which solved your issue.
For Touchgfx request, I advise you to create a new post on: STM32 MCUs TouchGFX and GUI | STM32 MCUs | Community forum.
Thank you.
ELABI.1
