NAlve.2450
Dec 10, 2019 12:51 PM UTC
How to compare bytes received in a uint8_t?
I have a STM32F103C8T card, I am developing an application that receives a byte array by usb / serial.
I have a variable "uint8_t USBBuffer;" in "usbd_cdc_if.c" which stores the bytes.
My question is: how can a non-vector variable receive an external multi-byte vector?
One of the vectors I get is this: {0x16, 0x16, 0x02, 0x00, 0x10, 0x03, 0x00, 0x00, 0x03}
I realized that I can store these bytes in a single index of a vector, eg: USBBuffer2 [0] = USBBuffer;
With this I can easily transmit USBBuffer2 with the CDC_Transmit function.
My question is, how is this vector stored in a uint8_t that is not a vector? how can i compare with another uint8_t variable?
Thanks in advance.
And I'm sorry if noob's question is that I'm just starting out in this universe.
Dec 10, 2019 1:55 PM UTC
Perhaps review chapter on pointers in C?
&USBBuffer​ would be the address for a uint8_t one byte array
Y​ou can use memcmp() to compare one or multiple bytes in memory.
Or do
if (a == x[i]) puts("same");
NAlve.2450
Dec 10, 2019 2:24 PM UTC
I have tried memcmp and have not been successful.
I've tried comparing with "if (var1 [i] == USBBuffer [i])" but as I mentioned earlier all bytes are in USBBuffer [0] and var1 [] = {0x16, 0x16, 0x02, 0x00, 0x10, 0x03 , 0x00, 0x00, 0x03}.
The problem is, I can't print USBBuffer to know how bytes are saved.
This would be easily solved if I have been using the Arduino IDE, but unfortunately my external application does not recognize my STM32 card if it is not recorded with STM32cubeIDE, I still can't figure out why.
Dec 10, 2019 2:58 PM UTC
Probably because you're trying to compare one thing against a dozen things.
uint8_t USBBuffer = 0x12;
printf("%02X\n", USBBuffer);
Or make a memory dumping function
dumpdata(16, &USBBuffer); // The byte that USBBuffer holds, and those surrounding it
Ok, but there's only ONE byte in your application of USBBuffer, you're going to have to accumulate bytes if you want to compare against multiples.
// Does byte match vector/array index i
if (var1 [i] == USBBuffer) printf("Byte Level match at %d\n", i);
// Accumulate a byte into an array
uint8_t BiggerBuffer[100], *p = BiggerBuffer;
*p++ = USBBuffer; // For each received byte to fill array
Trick here is
a) Understand data representation in memory properly
b) Learn C, variables, arrays
c) Learn Pointers
NAlve.2450
Dec 10, 2019 3:03 PM UTC
I really have a lot to learn yet, probably USBBuffer is just a pointer, I will deepen my studies in C.
Thank you very much.
