How to check the USB connect/disconnect run time?
We are using STMCubeMX to generate the code for USB-Device Mass Storage class for STM32L4R5 controller.
We have to check the usb connect/disconnect status run time.
Try to use HAL_PCD_ConnectCallback/HAL_PCD_DisconnectCallback function but never get call back here.
Please suggest how to use these call back function or any other method to check the USB status?
Thank you.
