Sep 25, 2025 9:50 AM UTC
How to achieve the expected standby current (JP4) on NUCLEO-U385RG-Q?
[Question]
How should I modify the sample project so that I can achieve the expected current consumption in standby mode (as described in the user manual)?
[Board]
  • NUCLEO-U385RG-Q
[Development Environment]
  • STM32CubeIDE 1.19.0
  • STM32CubeMX 6.15.0
[PWR_STANDBY]
I am using the sample project “PWR_STANDBY” generated from STM32CubeMX 6.15.0. I would like to modify this project for my purpose.
[Goal]
I want to put the board into standby mode, measure the current through JP4, and reproduce the expected value described in the user manual (https://www.st.com/resource/en/datasheet/stm32u385rg.pdf, page 115).
[Current Situation]
When I run the sample project without any modification, I measure about 255 µA. This is much higher than the expected value in the user manual.
Thank you for your advice and support.
KDJEM.1
KDJEM.1Best answer
Sep 26, 2025 9:58 AM UTC
Hello @AkasaDesu_1840 and welcome to the community;
Could you check your measuring device?
I recommend you to follow these steps:
- Debug PWR_STANDBY example
- Run the example.
- Stop run
- Remove JP4
- Connect an amperemeter to JP4 to measure IDD current.
On my side I tested the PWR_STANDBY example and I found that the standby current consumption is 0.6µA
Also, I used STLINK-V3PWR and I found the same results
Thank you.
Kaouthar
Shirley.Ye
Sep 26, 2025 9:51 AM UTC
you can download the STM32Cube package for U3 at STM32CubeU3 | Product - STMicroelectronics, the project is located at Projects\NUCLEO-U385RG-Q\Examples\PWR
KDJEM.1
KDJEM.1Best answer
- Run the example.
- Stop run
- Remove JP4
Thank you.
Kaouthar
Oct 1, 2025 5:32 AM UTC
Hello @KDJEM.1
Thank you for your response, and sorry for my late reply.
I was able to achieve a similar standby current to the user manual by following your method.
Best regards, AkasaDesu_1840.
