Fidk.1
Dec 27, 2022 9:38 PM UTC
how does one get time intervals on an stm32f10 using the standard libraries?
waclawek.jan
Dec 27, 2022 10:42 PM UTC
What do you mean by "get time intervals"?
Are you aware of the fact that SPL has been superseded by Cube years ago?
Fidk.1
Fidk.1Author
Dec 28, 2022 8:45 AM UTC
save the current time, wait, then subtract it from the new current time to get the time of something
Dec 27, 2022 11:00 PM UTC
Just enable the SysTick for 1ms (1000 Hz), and have a SysTick_Handler to increment a tick variable, perhaps also a local time/date clock
Or configure a TIM in maximal / free-run, say divided to 1 MHz, so you can delta time in micro-seconds, range about 65 ms via TIMx->CNT
Fidk.1
Fidk.1Author
Dec 28, 2022 8:47 AM UTC
I am not using the cube ide since I'm editing code that has been written and is compiled without it, so I am not sure as to how to do this
Dec 28, 2022 5:36 PM UTC
I'm not using CubeIDE either..
I'm not in a position to know your level of technical skill, education or training. Perhaps provide some context to understand what other experience you have. I need something to pivot off.
Perhaps get a programming manual for the Cortex-M3 more generally, the SysTick works on all these types of MCU exactly the same. Joseph Yiu has a good series of books.
STM32F10x_StdPeriph_Lib_V3.5.0\Project\STM32F10x_StdPeriph_Examples\SysTick\TimeBase
https://www.st.com/resource/en/programming_manual/pm0056-stm32f10xxx20xxx21xxxl1xxxx-cortexm3-programming-manual-stmicroelectronics.pdf
