NNaid
Sep 19, 2019 7:12 PM UTC
How do we integrate the GNSS Sample code for B-L475E-IOT01A1 with the GCP Sample code?
Aim: Sync STM32CubeExpansion_Cloud_GCP_V1.0.0 to STM32CubeExpansion_GNSS1_V3.0.0
Software GCP: https://www.st.com/en/embedded-software/x-cube-gcp.html
Software GNSS1: https://www.st.com/en/embedded-software/x-cube-gnss1.html
1.      GCP/Drivers/BSP/Components synced to GNSS/Drivers/BSP/Components
2.      GCP/Middlewares/Third_Party/LwIP and paho.mqtt.embedded-c synced with GNSS/Middlewares/Third_Party/ folder
3.      Copied GCP/Projects/Common to GNSS/Projects/Common
4.      Copied various files from GCP/Projects/B-L475E-IOT01A/Applications/Cloud/GoogleIoT/Inc
a.      googleiot.h
b.     vl53l0x_platform.h
c.      vl53l0x_proximity.h
5.      Copied various files from GCP/Projects/B-L475E-IOT01A/Applications/Cloud/GoogleIoT/Src
a.      vl53l0x_platform.c
b.     vl53l0x_proximity.c
6.      Copied googleiot.c to GNSS Project
7.      Copy GCP/Projects/Common/Shared to GNSS/Projects/B-L475-IOT01/Applications/A_GetPos/Common/Shared
GCP Include Paths to add to GNSS
../../../../../../../Common/GoogleIoT/Inc
../../../../../../../Common/Shared/Inc
../../../../../../../Middlewares/Third_Party/paho.mqtt.embedded-c/MQTTClient-C/src
../../../../../../../Middlewares/Third_Party/paho.mqtt.embedded-c/MQTTPacket/src
../../../../../../../../Drivers/BSP/Components/hts221
../../../../../../../../Drivers/BSP/Components/lis3mdl
../../../../../../../../Drivers/BSP/Components/lps22hb
../../../../../../../../Drivers/BSP/Components/lsm6dsl
../../../../../../../../Drivers/BSP/Components/vl53l0x
NOTES
1. Common Package clash
The Common packages that are used in both GNSS and GCP are clashing (Version code difference)
The GCP `iot_flash_config.h` and related files have the GCP connection code
The GNSS `iot_flash_config.h` and related files have option to only connect to BLUEMIX.
This stops the last compilation process in googleiot.c (Project Structure)
2. Dependencies on mbedTLS
GCP project uses googleiot_mbedtls_config.h whereas the GNSS project uses the httpclient_mbedtls_config.h.
This causes a clash when importing the libraries.
GCP Preprocessor Flags to add to GNSS
SENSOR
MQTTCLIENT_PLATFORM_HEADER=paho_mqtt_platform.h
GOOGLEIOT
