KPirs
Jan 10, 2019 4:31 PM UTC
How do i use HAL_ADC_ConfigChannel to read temperature sensor value in stm32f413 (and getting temperature instead of vbat)?
i generated HAL code with the latest version of stm32cubemx and the latest stm32f4 software package.
In the pinout configuration of stm32cubemx i checked the temperature channel, therefore the vbat is unchecked.
Using the function HAL_ADC_ConfigChannel of stm32f4xx_hal_adc.c to set the channels and corresponding ranks to read, i set for example the ADC_CHANNEL_TEMPSENSOR channel.
That channel is defined as channel 18 in stm32f4xx_hal_adc_ex.h:
#if defined(STM32F413xx) || defined(STM32F423xx)
#define ADC_CHANNEL_TEMPSENSOR ((uint32_t)ADC_CHANNEL_18)
#endif /* STM32F413xx || STM32F423xx */ ,
which corresponds to the reference manual.
The vbat channel is as well channel 18 due to reference manual and set in stm32f4xx_hal_adc.h:
#define ADC_CHANNEL_VBAT    ((uint32_t)ADC_CHANNEL_18)
If the vbate bit is now set in the CCR register of the ADC, channel18 outputs the vbat value instead of temperature.
In the function HAL_ADC_ConfigChannel now on input ADC_CHANNEL_TEMPSENSOR of the sConfig the software does not distinguish between ADC_CHANNEL_TEMPSENSOR and ADC_CHANNEL_VBAT as both are defined as ADC_CHANNEL_18. The vbate bit is therefore set and temperature not read, instead the vbat value:
HAL_StatusTypeDef HAL_ADC_ConfigChannel(ADC_HandleTypeDef* hadc, ADC_ChannelConfTypeDef* sConfig)
 __IO uint32_t counter = 0U;
 ADC_Common_TypeDef *tmpADC_Common;
 /* Check the parameters */
 assert_param(IS_ADC_CHANNEL(sConfig->Channel));
 assert_param(IS_ADC_REGULAR_RANK(sConfig->Rank));
 assert_param(IS_ADC_SAMPLE_TIME(sConfig->SamplingTime));
 /* Process locked */
 __HAL_LOCK(hadc);
 /* if ADC_Channel_10 ... ADC_Channel_18 is selected */
 if (sConfig->Channel > ADC_CHANNEL_9)
  /* Clear the old sample time */
  hadc->Instance->SMPR1 &= ~ADC_SMPR1(ADC_SMPR1_SMP10, sConfig->Channel);
  /* Set the new sample time */
  hadc->Instance->SMPR1 |= ADC_SMPR1(sConfig->SamplingTime, sConfig->Channel);
 else /* ADC_Channel include in ADC_Channel_[0..9] */
  hadc->Instance->SMPR2 &= ~ADC_SMPR2(ADC_SMPR2_SMP0, sConfig->Channel);
  hadc->Instance->SMPR2 |= ADC_SMPR2(sConfig->SamplingTime, sConfig->Channel);
 /* For Rank 1 to 6 */
 if (sConfig->Rank < 7U)
  /* Clear the old SQx bits for the selected rank */
  hadc->Instance->SQR3 &= ~ADC_SQR3_RK(ADC_SQR3_SQ1, sConfig->Rank);
  /* Set the SQx bits for the selected rank */
  hadc->Instance->SQR3 |= ADC_SQR3_RK(sConfig->Channel, sConfig->Rank);
 /* For Rank 7 to 12 */
 else if (sConfig->Rank < 13U)
  hadc->Instance->SQR2 &= ~ADC_SQR2_RK(ADC_SQR2_SQ7, sConfig->Rank);
  hadc->Instance->SQR2 |= ADC_SQR2_RK(sConfig->Channel, sConfig->Rank);
 /* For Rank 13 to 16 */
 else
  hadc->Instance->SQR1 &= ~ADC_SQR1_RK(ADC_SQR1_SQ13, sConfig->Rank);
  hadc->Instance->SQR1 |= ADC_SQR1_RK(sConfig->Channel, sConfig->Rank);
  /* Pointer to the common control register to which is belonging hadc  */
  /* (Depending on STM32F4 product, there may be up to 3 ADCs and 1 common */
  /* control register)                          */
  tmpADC_Common = ADC_COMMON_REGISTER(hadc);
 /* if ADC1 Channel_18 is selected enable VBAT Channel */
 if ((hadc->Instance == ADC1) && (sConfig->Channel == ADC_CHANNEL_VBAT))
  /* Enable the VBAT channel*/
  tmpADC_Common->CCR |= ADC_CCR_VBATE;
 /* if ADC1 Channel_16 or Channel_17 is selected enable TSVREFE Channel(Temperature sensor and VREFINT) */
 if ((hadc->Instance == ADC1) && ((sConfig->Channel == ADC_CHANNEL_TEMPSENSOR) || (sConfig->Channel == ADC_CHANNEL_VREFINT)))
  /* Enable the TSVREFE channel*/
  tmpADC_Common->CCR |= ADC_CCR_TSVREFE;
  if((sConfig->Channel == ADC_CHANNEL_TEMPSENSOR))
   /* Delay for temperature sensor stabilization time */
   /* Compute number of CPU cycles to wait for */
   counter = (ADC_TEMPSENSOR_DELAY_US * (SystemCoreClock / 1000000U));
   while(counter != 0U)
    counter--;
 /* Process unlocked */
 __HAL_UNLOCK(hadc);
 /* Return function status */
 return HAL_OK;
What am i missing? Is there any additional configuration i have to make somewhere?
Regards, Kjell Pirschel
