mo'br
Aug 23, 2019 6:40 AM UTC
How can I install the X Cube Audio Package 1.1.1 into STM Cube MX ?
When I click on install or remove embedded software packages, using both install from local and use URL fail. When I have the package zip file local I get the error "The given file is not recognized as beeing (spelt wrong!) valid. It must either be a MCU or CMIS pack". So I presume I do something else with this expansion pack as its not a MCU or a CMIS ?
Houssem CHAABANI
Nov 27, 2020 8:17 AM UTC
Dear @mo'br​ ,
Could you please share the .ioc file and try to use the last available version of STM32CubeMX.
Kind regards,
Houssem
cmdr
Dec 28, 2020 2:39 AM UTC
I have the same problem. I tried CubeMX version 6.1.1. I don't have an .ioc file because this happens before creating a project.
I'm also wondering why the Audio package does not appear in the list in the Embedded Software Packages Manager along with the other X-CUBE-* entries.
x893-00
Aug 2, 2021 12:40 AM UTC
  • It `s Magic
ST programming guru's answer
