RRuoc.1
Oct 8, 2021 7:58 AM UTC
How can I communicate with my HOST MCU via USB with a Device MCU, if the device only uses an FTDI chip?
My Partner has an hardware, which only communicate over USB (FTDI) with other hardware platforms. At the moment there is no possibilty to change the hardware.
Unfortunately I have to write the USB Host with my STM32H7A3ZI. My first steps was to use the generated code from CubeMX. My Host get the Device Describtion and Configuration but there is no chance of communication between the host and devices. It always ends in the HOST_ABORT_STATE.
Does somebody has an idea?
Lubos KOUDELKA
Lubos KOUDELKABest answer
Oct 8, 2021 8:05 AM UTC
FTDI has some differences compared to CDC-ACM. You can find some information about differences in other articles on web.
ST is now offering Azure RTOS middleware including USBX solution, which includes also FTDI class support (called prolific). Please check
https://www.st.com/en/embedded-software/x-cube-azrtos-h7.html
Lubos KOUDELKA
RRuoc.1
RRuoc.1Author
Oct 8, 2021 8:06 AM UTC
Thanks!
RRuoc.1
RRuoc.1Author
Oct 13, 2021 1:57 PM UTC
:beaming_face_with_smiling_eyes:
RRuoc.1
RRuoc.1Author
Oct 15, 2021 7:48 AM UTC
RRuoc.1
RRuoc.1Author
Nov 15, 2021 4:29 PM UTC
@Lubos KOUDELKA​  do you have an example for prolific? I could send, but I have still problems to receive data. Therefore I would like to compare to a working project. Thanks!
