JAgni.1
Nov 24, 2021 11:34 AM UTC
Hi, I am trying to port X-CUBE-USB-AUDIO package to my project with different MCU- STM32F446RE. I have ported all the files related to mic node (no change in BSP) but getting -USB not recognised error. How can I use this Package with different BSP?
Snara.21
Senior
Nov 25, 2021 6:55 AM UTC
@JAgni.1​  Check the USB Port Pins are same and Clock Settings . In schematics check the MIC (Analog or Digital). If you have same target board working fine, Check once more .
If target board share the error then the it could be the cable or debugging connection issue
JAgni.1
JAgni.1Author
Nov 25, 2021 12:22 PM UTC
@Snara.2​ Thank you for your quick reply. I have checked USB Port pins and clock settings. That error message is gone now, there was issue with USB cable. But still STM32F446RE not getting detected as USB Mic. I am using only mic node of X-CUBE package. I have ported Application/User files to my own project keeping Board support package,drivers as it is(hardware). Do I need to do any setting for USB enumeration? I have been stuck at this point for many days. I appreciate your help.
JAgni.1
JAgni.1Author
Dec 6, 2021 12:19 PM UTC
I have resolved that USB enumeration issue. But using X-CUBE-USB-AUDIO package, I am not able to record any voice. Is there any utility that needs to be use to make this package work properly? Please help me. Thank you in advance.
