There are the disk_read(), disk_write() etc functions that your projects provide, and fatfs calls these to handle the actual I/O requests. They each take a drive number as the first parameter, which is probably ignored in your projects.
Merge these functions to call the respective disk i/o functions according to the disk number parameter. E.g. you can rename disk_read() from one project to disk_read_sd, and the other one to disk_read_usb(), then write
DRESULT disk_read(BYTE pdrv,BYTE* buff,LBA_t sector,UINT count) {
switch(pdrv) {
case 0:
return disk_read_sd(pdrv,buff,sector,count);
case 1:
return disk_read_usb(pdrv,buff,sector,count);
// handle wrong drive number error here
Now you can use filenames starting with the drive number and a colon, e.g.
f_open(FIL *f1, "0:file1.txt", FA_READ); // opens a file on the SD card
f_open(FIL *f2, "1:file2.txt", FA_READ); // opens a file on the USB drive
and disk accesses will be directed to the appropriate i/o functions.
