Jan 24, 2025 7:58 AM UTC
HardFault_Handler() at stm32l0xx_it.c:85 0x80008b4
MX_GPIO_Init();
MX_SPI2_Init();
MX_USART2_UART_Init();
MX_FATFS_Init();
/* USER CODE BEGIN 2 */
W25Qxxx_Init();
fres = f_mount(&fs,"0:",1);
if(fres == FR_OK)
v=9;
fres = f_open(&fp, "info.txt", FA_OPEN_ALWAYS|FA_WRITE);
else
v=2;
trying to use spi flash using fatfs .
but occur hardfault handler when calling fopen . i am not sure whether it is from fopen or not.
mƎALLEm
mƎALLEmBest answer
Jan 24, 2025 8:29 AM UTC
Hello @NOVAL_______BOBY and welcome to the community,
Need to validate your read / write operation to the SPI Flash memory "W25Qxxx" before implementing FatFs on it.
mƎALLEm
mƎALLEmBest answer
Jan 24, 2025 10:07 AM UTC
tried read and write operations worked successfuly but when i try this again
fres = f_mkfs("0:", FM_FAT, 0, worK, sizeof(worK));
if(fres == FR_OK) {
v=9;
else {
v=fres;
i got
Thread #1 [main] 1 [core: 0] (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
HardFault_Handler() at stm32l0xx_it.c:85 0x80008d8
<signal handler called>() at 0xfffffff9
HAL_SPI_TransmitReceive() at stm32l0xx_hal_spi.c:1,308 0x8003128
HAL_SPI_Receive() at stm32l0xx_hal_spi.c:979 0x8002ca4
W25Qxxx_ReadPage() at w25q32.c:800 0x80010a8
W25Qxxx_ReadSector() at w25q32.c:839 0x8001160
W25Qxxx_diskio_read() at w25q32.c:974 0x8001250
disk_read() at diskio.c:122 0x800406c
move_window() at ff.c:925 0x80045fe
check_fs() at ff.c:2,971 0x80053f8
<...more frames...>
what should be reason any idea??
Jan 24, 2025 11:44 AM UTC
Duplicate - merged.
tried read and write operations worked successfully but when i try this again
if(fres == FR_OK) {
 v=9;
else {
 v=fres;
i got
() at 0xfffffff9
<...more frames...>
Post edited to format code - please see this for posting source code, and this for other "formatted" text.
mƎALLEm
Jan 24, 2025 11:49 AM UTC
