HAL_UART_DeInit() behaves unexpectedly
I have several UARTs when initializing them all simply with HAL_UART_Init , each with its own UART_HandleTypeDef instance, than things works fine.
But on adding HAL_UART_DeInit before HAL_UART_Init (this is actually the generated code from stm32cube) , than the second UARTinit resulted in malfunction of the first UART.
I have verified that the instance of UART_HandleTypeDef is not the same.
Any idea why it behaves like this ?
Thanks,
ranran
