stigmablu
HAL SPI DMA Transmit vs TransmitReceive
  • May 30, 2015
  • 0 replies
  • 510 views
Posted on May 30, 2015 at 04:14
Hi, when dealing with SPI with DMA this works:
SPI_CS_on();
if
(HAL_SPI_TransmitReceive_DMA(&hspi2, &dataout, &input, 1) != HAL_OK) {
/* error */
while
(HAL_SPI_GetState(&hspi2) != HAL_SPI_STATE_READY) {
/* wait */
SPI_CS_off();
while this doesn't (blocking program flows):
SPI_CS_on();
if
(HAL_SPI_Transmit_DMA(&hspi2, &dataout, 1) != HAL_OK) {
/* error */
while
/* wait */
SPI_CS_off();
the only way to have
to work is by using it AFTER
or after manually calling __HAL_SPI_ENABLE(&hspi2); like so:
dataout = 0x85;
SPI_CS_on();
if
/* error */
while
/* wait */
SPI_CS_off();
any idea? is
supposed to work this way? thanks. #dma #hal #spi
