gdori.1
Jun 27, 2021 10:11 PM UTC
HAL/LL documentation?
Hello all,
Is there a reference doc about the HAL/LL for ST's 32F439 ARM MCU?
I want to know the function structure and just want to know how it works and to have control over how I set up my devices.
thanks George
TDKBest answer
Jun 27, 2021 10:23 PM UTC
The best reference is in the code itself which document each function. E.g:
 * @brief Sends an amount of data in blocking mode.
 * @param huart pointer to a UART_HandleTypeDef structure that contains
 * the configuration information for the specified UART module.
 * @param pData Pointer to data buffer
 * @param Size Amount of data to be sent
 * @param Timeout Timeout duration
 * @retval HAL status
HAL_StatusTypeDef HAL_UART_Transmit(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size, uint32_t Timeout)
 uint16_t* tmp;
 uint32_t tickstart = 0U;
However, there is also this:
https://www.st.com/resource/en/user_manual/dm00105879-description-of-stm32f4-hal-and-ll-drivers-stmicroelectronics.pdf
TDKBest answer
 uint16_t* tmp;
