Noirim DIH
Feb 5, 2018 12:23 PM UTC
HAL_GPIO_EXTI_Callback with both USB and GPIO
Posted on February 05, 2018 at 13:23
Hello, I'm facing a difficulty using CubeMx generated code with USB (CDC with VBus sensing).
HAL_GPIO_EXTI_Callback is declared as 'weak' so for managing some GPIO's interrupts, I declared my own call back to 'catch gpio's interruption' and everything works fine. Now I'm trying to add USB CDC and it appears that in usb_conf.c file, HAL_GPIO_EXTI_Callback is redefine to manage VBus detection. So now I have in my project a double declaration for this callback : in the user code and in the code generated by CubeMx.
Is there any simple way to deal with this?
#hal_gpio_exti_callback #usb-with-gpio
Pavel A.
Feb 5, 2018 7:50 PM UTC
Posted on February 05, 2018 at 20:50
You will need to combine both routines in one place, of your choice.
-- pa
Noirim DIH
Feb 6, 2018 8:17 AM UTC
Posted on February 06, 2018 at 08:17
Hello, thanks for your reply. That exactly the purpose of my question. How can I merge both routine without modifying generated code (from CubeMx).Is there some configuration or can I had some 'User code tag' to prevent overrides after an update?
Pavel A.
Feb 11, 2018 12:29 AM UTC
Posted on February 11, 2018 at 00:29
Sometimes this concept of 'user code' does not work and we have to merge manually.
Gene Toner
Feb 10, 2018 11:18 PM UTC
Posted on February 11, 2018 at 00:18
X2 on this problem and Hassan Chiker's response. Some kind of 'User code tag' would be a great 'get out of jail free card' for all bugs like this in CubeMX.
