Yoichi Shinoda
Senior
Feb 18, 2020 1:45 PM UTC
H7 FW V1.6.0, H7A3, incorrect internal ADC calibration value locations
H7 FW V1.6.0 has incorrect VREFINT_CAL_ADDR, TEMPSENSOR_CAL1_ADDR and TEMPSENSOR_CAL2_ADDR definitions for H7A3.
Correct defs would be
#define VREFINT_CAL_ADDR ((uint16_t *)0x8fff810)
#define TEMPSENSOR_CAL1_ADDR ((uint16_t *)0x8fff814)
#define TEMPSENSOR_CAL2_ADDR ((uint16_t *)0x8fff818)
and these should be conditional to H7A3 (and possibly others). Currently, same def with H74x/H75x are used.
Imen.DBest answer
Feb 19, 2020 2:11 PM UTC
Hello @Yoichi Shinoda​ ,
Thank you for highlighting this issue. I raised it internally for fix in the next releases.
Best Regards,
Imen
Mike_ST
Feb 18, 2020 4:45 PM UTC
Thank you for reporting,
While I was checking too, I could see that @Imen DAHMEN has just entered a ticket for that.
Yoichi Shinoda
Senior
Feb 18, 2020 7:55 PM UTC
Thank you always for your investigation work.
And while you are at it, can you please take a quick look at another questions I have regarding H7A3 USB DFU memory descriptor?
https://community.st.com/s/question/0D50X0000C6cXYVSQ2/h7a3zi-returns-incorrect-dfu-memory-descriptor
Imen.DBest answer
Best Regards,
Imen
