Github STM32Cube4 v1.6.2 does not contain core_cm4.h anymore
As mentioned in the title already, the file core_cm4.h is not contained in the recent version of
https://github.com/STMicroelectronics/STM32CubeG4
anymore.
Selecting the v1.6.1. in that repo the file is contained.
Looks like there was an error genererating the new version.
mƎALLEm
mƎALLEmBest answer
Hello @wimalopaan ,
It seems the issue has been solved.
Could you please check again from your side?
mƎALLEm
I will escalate the issue internally for fix. Internal ticket 227877 for follow-up.
Thank you for your contribution.
mƎALLEm
mƎALLEmBest answer
Hello @wimalopaan ,
Perfect.
Works for me!
mƎALLEm
Ok I'll close this post then.
