Apr 16, 2025 11:51 PM UTC
FreeRtos Runtime Stats
I am experimenting FreeRTOS to learn how to use it and CubeIde.  Simple stuff right now.  I am attempting to implement the runtime stats as described in  V10.1 FreeRTOS Reference Manual (p 86) and am having two problems.
First, the TaskStatus_t {pxTaskStatusArray[ x ].ulRunTimeCounter ] reurns 0 for ulRunTimeCounter. so the runtime_percent is always zero.  I have configGENERATE_RUN_TIME_STATS  set to 1 in  FreeRTOSConfig.h.
Any clarification would be appreciated
Pavel A.
Apr 17, 2025 12:16 PM UTC
Have you implemented  portCONFIGURE_TIMER_FOR_RUN_TIME_STATS and portGET_RUN_TIME_COUNTER_VALUE ?
GreybeardAuthor
Apr 18, 2025 11:06 AM UTC
Thanks for the insight.  I was overthinking the problem and focusing on FreeRtos.
