SGian.1
Jul 11, 2026 10:04 UTC
Flash and data
Hi there !
I have a quick question about where the data are save. If i create one const array [1024] the data inside the array (because i write the word const in front) are save inside the falsh ? and this give to me more space in the ram  right ? and is the same if i create one struct and i acces with pointer ?  and please some one can help me and show where i can find all this kind of information like book tutorial website youtube ect
Thank you
Sergio
Khaled_DHIFBest answer
Jul 13, 2026 15:51 UTC
Hello ​@SGian.1 ,
Yes, in embedded C, const data is usually placed in flash, so it saves RAM. But this depends on the compiler/linker, so it’s not guaranteed by const alone.
A struct is different: where it is stored depends on how you declare it, not on whether you access it with a pointer. A pointer only gives access to the data; it does not move it to flash or RAM.
A good rule of thumb:
  • const data → often flash
  • non-const data → usually RAM
  • pointer → only an address
If you want to learn more, search for:
  • Memory layout (per MCU in the corresponding STM32 RM)
  • linker script .data .bss .rodata (per compiler)
Kind regards,
DHIF Khaled
"Please mark my answer as best by clicking on the “Accept as solution"" button if it fully answered your question. This will help other users find this solution faster.​"
Hello ​@SGian.1 ,
Kind regards,
DHIF Khaled
SGian.1
SGian.1Author
Jul 13, 2026 17:27 UTC
Thank you soo much , have a nice day
Sergio
