yang hong
firmware version information
  • September 17, 2019
  • 1 reply
  • 427 views
I am using NUCLEO-F429ZI. I would like to add my application name, author, firmware version and so on information into application profile, how can I add them when I compile the program and save these information into controller?
thank you.
September 17, 2019
You'd typically use strings, and mark them so the linker doesn't discard them
#ifdef __ICCARM__        //IAR
#define KeepInCompilation __root
#elif __CC_ARM          //MDK-ARM
#define KeepInCompilation __attribute__((used))
#else //TASKING        //TrueStudio
#endif
KeepInCompilation static const char foo[]= "Firmware XYZ, Written by ABC";
