Feb 13, 2025 2:23 PM UTC
FileX on NUCLEO-H723ZG
Hey there,
I recently started learning how to use Azure RTOS on STM32 with NUCLEO-h723ZG Board. While following this course
Developing with Azure RTOS on STM32 Series Microcontrollers
https://academy.st.com/s/learning-plan-detail-standard?ltui__urlRecordId=a6g3W000000k9jMQAQ&ltui__urlRedirect=learning-plan-detail-standard&tabset-7a350=2
I came accross the FileX section in Session 6. At slide 31 the course wants me to delete a file and copy some other from a specific directory. As I'm using a higher version than the course I was not able to find the FileX folder in the directory mentioned.
What can I do about this problem, because I can't proceed my learning process with FileX? Is there any up-to-date-Guide that  I can follow along?
May 15, 2025 3:51 PM UTC
Hello @VincentKochinke
Did you try to use the version used on the course?
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
