IVent.1
Senior
Sep 6, 2024 9:10 AM UTC
filex and directory/files
Hallo, this is my code.
I create a directory, and then a file in this directory. If, in another point of the code, I check if the file is present or not, I can read/write it correctly and so on.
Instead, if I stop the execution of the program, when I restart it, I don't find the file above, only the directory.
Any suggestion please? I'm struggling with it...
fxRes = fx_media_open(
&disk1,
"FS",
fx_stm32_levelx_nor_driver,
(VOID *)LX_NOR_OSPI_DRIVER_ID,
(VOID *) fx_nor_ospi_media_memory,
sizeof(fx_nor_ospi_media_memory));
if (FX_SUCCESS != fxRes) {
return;
if (!FolderExists(&disk1, (char*)"/DATA"))
fxRes=_fx_directory_create(&disk1, (char*)"/DATA");
return;
if (!FileExists(&disk1, (char*)"/DATA/file.txt"))
fxRes=_fx_file_create(&disk1, (char*)"/DATA/file.txt");
return;
fx_media_flush(&disk1);
fx_media_close(&disk1);
mƎALLEm
Sep 6, 2024 11:43 AM UTC
Hello @IVent.1 ,
Please kindly use </>  button to paste your code. I've edited your post then.
MFARH.1
Sep 6, 2024 3:25 PM UTC
 To resolve this issue, we need to ensure that we correctly test the FX_ALREADY_CREATED condition when creating directories and files.
fxRes = fx_media_open(&disk1, "FS",
 return;
 if (FX_ALREADY_CREATED != fxRes)
 return;
 retrun;
IVent.1
IVent.1Author
Senior
Sep 9, 2024 8:40 AM UTC
<fxRes=_fx_directory_create(&disk1, (char*)"/DATA");
 return;
 retrun;
these 2 _fx_file_create result successfully.
But if I switch off and then on the board, the file created inside the directory is not present anymore.
This is my issue.
MFARH.1
Sep 9, 2024 8:56 AM UTC
Could you please tell me which version of the FileX middleware you are currently using?
