mfrank9
Jul 12, 2021 1:43 PM UTC
FATFS: show all files
is it possibility to show a list of files and folders with the fatfs library?
Like "ls" in the console.
Tesla DeLoreanBest answer
Jul 12, 2021 5:20 PM UTC
The FatFs library provides you with the means to implement this, but not the code, although you might find some if you look.
Typically a problem that can be solved via recursive, or queued linear, traversal
For a simple single level
puts("Display Directory");
 DIR dir;
 char *path;
 UINT BytesWritten;
 char string[128];
 path = ""; // where you want to list
 res = f_opendir(&dir, path);
#ifdef DBG
 if (res != FR_OK)
 printf("res = %d f_opendir\n", res);
#endif
 if (res == FR_OK)
 while(1)
 FILINFO fno;
 res = f_readdir(&dir, &fno);
#ifdef DBG
 if (res != FR_OK)
 printf("res = %d f_readdir\n", res);
#endif
 if ((res != FR_OK) || (fno.fname[0] == 0))
 break;
 sprintf(string, "%c%c%c%c %10d %s/%s",
 ((fno.fattrib & AM_DIR) ? 'D' : '-'),
 ((fno.fattrib & AM_RDO) ? 'R' : '-'),
 ((fno.fattrib & AM_SYS) ? 'S' : '-'),
 ((fno.fattrib & AM_HID) ? 'H' : '-'),
 (int)fno.fsize, path, fno.fname);
 puts(string);
SBEN .2
Jul 12, 2021 4:26 PM UTC
Hello @mfrank9​ ,
It is possible to recursively travers the file tree using FATFS and display its content using f_readdir(). A limited example, for inspiration, can be found in the implementation of kStorage_GetDirectoryFiles() (See here) in the STM32G474E-EVAL demonstration project.
Best regards,
@SBEN .2​
 DIR dir;
 char *path;
 UINT BytesWritten;
 char string[128];
#ifdef DBG
 if (res != FR_OK)
#endif
 if (res == FR_OK)
 while(1)
 FILINFO fno;
#ifdef DBG
 if (res != FR_OK)
#endif
 break;
 puts(string);
mfrank9
mfrank9Author
Jul 20, 2021 9:29 AM UTC
Thank you!
That works.
The following lines don't do what they're supposed to, but I don't know why.
This is not a problem as they work when called individually.
TBode.1
Jan 26, 2023 9:55 AM UTC
Thanks!
Helped me much.
