Failing to recreate LWIP example code on NUCLEO-H743ZI2
I am trying to create a simple UDP server using the NUCLEO-H743ZI2 board. I will port this to a similar microcontroller in the same family (STM32H750B) once I get it working. I am able to build the example code from this repository:
https://github.com/stm32-hotspot/STM32H7-LwIP-Examples/tree/main/STM32H743_Nucleo_ETH
It successfully responds to pings and shows up in my router device list. I used:
STM32CubeIDE Version: 1.17.0
STM32Cube FW_H7 Version 1.12.1.
Following the instructions in the README, I attempted to build the application from scratch on the NUCLEO board, but I haven't been able to get it to respond to a ping despite a few days of troubleshooting.
Can someone tell me if there is something wrong with my configuration file?
STackPointer64Best answer
Hello @aa_hunter, and welcome to ST community!
Attached is a project for the NUCLEO-H753. You can compare configurations and have a working project. Please make sure to add the proper linker file configuration to your project. Let me know if you need further assistance.
Best regards,
To improve visibility of answered topics, please click 'Accept as Solution' on the reply that resolved your issue or answered your question.
aa_hunterAuthor
Best regards,
aa_hunterAuthor
Thanks STackPointer64! I will compare against my config and let you know of any questions.
Hello @aa_hunter,
Have you been able to identify the issue causing your application to malfunction?
Best regards,
aa_hunterAuthor
Thanks Stackpointer,
I haven't completed testing the solution you provided yet--I'm currently on travel and it could be a couple of weeks before I will have time to test it, but I will follow up here once I do.
Thanks!
