Konstantin Maslennikov
F407 and lis3dsh
  • February 23, 2018
  • 11 replies
  • 2410 views
Posted on February 23, 2018 at 15:01
I'm try use only registers for lis3dsh.
https://community.st.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2Fmas-kon%2FF407-LIS3DSH
- my code. This code sometimes is worked, but sometimes it stopped. Can any help my?
#cmsis #registers #lis3dsh
Note: this post was migrated and contained many threaded conversations, some content may be missing.
Andrew Neil
Posted on February 23, 2018 at 15:17
So what debugging have you done?
Posted on February 23, 2018 at 16:08
Anytime funtion
uint8_t SPI1SendData(uint8_t data)
while (!(SPI1->SR & SPI_SR_TXE)){};
SPI1->DR = data;
while (!(SPI1->SR & SPI_SR_RXNE)){};
data = SPI1->DR;
return data;
return 0xFF.
Why, I don,t know...
Bogdan Golab
Lead
February 23, 2018
Posted on February 23, 2018 at 16:12
Looks like CS (chip select) is not enabled or sensor internal register address embedded in data sent to the sensor is wrong
Andrew Neil
Posted on February 23, 2018 at 19:22
Similar question just posted:
https://community.st.com/0D50X00009XkgQkSAJ
