Jul 29, 2024 5:05 AM UTC
Example of OpenAMP send message from core M4 to M7 (Nucleo H745ZI)
Hello everyone,
I am using Nucleo H745ZI dual core and I want to communicate intercore by OpenAMP.
The ST only giving example send message from core M7 to M4. But I want to send message from core M4 to M7, I tried follow the OpenAMP flowchart but not working.
Do anyone has the example of OpenAMP send message from M4 to M7?
mƎALLEm
mƎALLEmBest answer
Sep 9, 2025 11:32 AM UTC
Check the oscilloscope example X-CUBE-H7DC-APP, it is using OpenAMP. Most probably CM4 is converting an external analog signal and it is sending the samples (using OpenAMP) to CM7 to display it and apply the FFT.
EDIT:
Indeed, it does (from the data brief:(
mƎALLEm
mƎALLEmBest answer
EDIT:
