Jul 22, 2024 3:48 AM UTC
ethernetif.c File and misra-c:2012 2.3 Issue(?)
In the ethernetif.c file,
typedef enum
RX_ALLOC_OK = 0x00,
RX_ALLOC_ERROR = 0x01
} RxAllocStatusTypeDef; // Here, RxAllocStatusTypeDef type is not used.
It says that RxAllocStatusTypeDef is not used, which violates misra-c:2012 2.3.
Inferentially, this would require changing the type in the following code:
[before]
static uint8_t RxAllocStatus;
[after]
static RxAllocStatusTypeDef RxAllocStatus;
It looks like the code should be changed, what do you think?
ASEHSTBest answer
Jul 22, 2024 9:12 AM UTC
Hello @lovewar;,
Thank you for your report and for bringing this to our attention.
Internal ticket number: 187110
With Regards,
"If your question is answered, please close this topic by clicking ""Accept as Solution""."
ASEHSTBest answer
Hello @lovewar;,
With Regards,
