svii
May 10, 2021 7:57 AM UTC
Ethernet webserver how to generate static webpage?
hi i am using cubemx and generated an ethernet webserver project from example on nucleo f429i board it is working with default webserver page.
However i need to use my own custom webpage , but do not know how to generate static webpage i followed some videos on youtube to generate webpages using perl makefs but is not working . I am doing somethin wrong . can anyone share any procedure how to compile a webpage any tutorial will be helpful on this ,i am using windows 10 and cubemx 5.0 ,Thank you in advance.
Walid ZRELLI
May 20, 2021 5:23 PM UTC
Hello @svii​ ,
Take a look at this video it might help you.
BeST Regards,
Walid
svii
sviiAuthor
Jun 8, 2021 11:43 AM UTC
hi thanks ,checked the video got it working static webpage, need reference for dynamic webpage support login user.
